[GRASS-dev] Re: [GRASS-GUI] how i can change the watershed analysis technique?
Mohammed Rashad mohammedrashadkm at gmail.com
Mon Nov 14 08:47:08 EST 2011
you run from grass shell
r.watershed --interface-description 2> gui.xml
open gui.xml in an text editor. parse the xml using some xml parsers i use
pugixml and then create your own gui.
you can also make a standalone application if you link your application
with libgrass* libraries
please see below your required xml output genreated by r.watershed
<!DOCTYPE task SYSTEM "grass-interface.dtd">
<task name="r.watershed">
<description>
Watershed basin analysis program.
 </description>
<keywords>
raster
 </keywords>
<parameter name="elevation" type="string" required="yes" multiple="no">
 <description>
Input map: elevation on which entire analysis is based
 </description>
<keydesc>
<item order="1">name</item>
 </keydesc>
<gisprompt age="old" element="cell" prompt="raster" />
 <guisection>
Input_options
</guisection>
 </parameter>
<parameter name="depression" type="string" required="no" multiple="no">
 <description>
Input map: locations of real depressions
</description>
 <keydesc>
</keydesc>
<guisection>
 Input_options
</guisection>
</parameter>
 <parameter name="flow" type="string" required="no" multiple="no">
<description>
 Input map: amount of overland flow per cell
</description>
<keydesc>
</keydesc>
 <guisection>
Input_options
</guisection>
 </parameter>
<parameter name="disturbed.land" type="string" required="no" multiple="no">
 <description>
Input map or value: percent of disturbed land, for USLE
 </description>
 <guisection>
Input_options
</guisection>
 </parameter>
<parameter name="blocking" type="string" required="no" multiple="no">
 <description>
Input map: terrain blocking overland surface flow, for USLE
 </description>
<keydesc>
 </keydesc>
 <guisection>
Input_options
</guisection>
 </parameter>
<parameter name="accumulation" type="string" required="no" multiple="no">
 <description>
Output map: number of cells that drain through each cell
 </description>
<keydesc>
 </keydesc>
<gisprompt age="new" element="cell" prompt="raster" />
 <guisection>
Output_options
</guisection>
 </parameter>
<parameter name="drainage" type="string" required="no" multiple="no">
 <description>
Output map: drainage direction
</description>
 <keydesc>
</keydesc>
<guisection>
 Output_options
</guisection>
</parameter>
 <parameter name="basin" type="string" required="no" multiple="no">
<description>
 Output map: unique label for each watershed basin
</description>
 <keydesc>
</keydesc>
<guisection>
 Output_options
</guisection>
</parameter>
 <parameter name="stream" type="string" required="no" multiple="no">
<description>
 Output map: stream segments
</description>
<keydesc>
</keydesc>
 <guisection>
Output_options
</guisection>
 </parameter>
<parameter name="half.basin" type="string" required="no" multiple="no">
 <description>
Output map: each half-basin is given a unique value
 </description>
<keydesc>
 </keydesc>
 <guisection>
Output_options
</guisection>
 </parameter>
<parameter name="visual" type="string" required="no" multiple="no">
 <description>
Output map: useful for visual display of results
</description>
 <keydesc>
</keydesc>
<guisection>
 Output_options
</guisection>
</parameter>
 <parameter name="length.slope" type="string" required="no" multiple="no">
<description>
 Output map: slope length and steepness (LS) factor for USLE
</description>
 <keydesc>
</keydesc>
<guisection>
 Output_options
</guisection>
</parameter>
 <parameter name="slope.steepness" type="string" required="no"
multiple="no">
<description>
 Output map: slope steepness (S) factor for USLE
</description>
<keydesc>
</keydesc>
 <guisection>
Output_options
</guisection>
 </parameter>
<parameter name="threshold" type="integer" required="no" multiple="no">
 <description>
Input value: minimum size of exterior watershed basin
 </description>
<guisection>
Input_options
 </guisection>
</parameter>
<parameter name="max.slope.length" type="float" required="no" multiple="no">
 <description>
Input value: maximum length of surface flow, for USLE
 </description>
<guisection>
Input_options
 </guisection>
</parameter>
<parameter name="convergence" type="integer" required="no" multiple="no">
 <label>
Convergence factor for MFD (1-10)
</label>
 <description>
1 = most diverging flow, 10 = most converging flow. Recommended: 5
 </description>
<default>
5
 </default>
</parameter>
<parameter name="memory" type="integer" required="no" multiple="no">
 <description>
Maximum memory to be used with -m flag (in MB)
</description>
 <default>
300
</default>
 </parameter>
<flag name="f">
<label>
 Enable MFD flow (default is SFD (D8))
</label>
<description>
 SFD: single flow direction, MFD: multiple flow direction
</description>
 </flag>
<flag name="4">
<description>
 Allow only horizontal and vertical flow of water
</description>
</flag>
 <flag name="m">
<label>
Enable disk swap memory option: Operation is slow
 </label>
<description>
Only needed if memory requirements exceed available RAM; see manual on how
to calculate memory requirements
 </description>
</flag>
<flag name="a">
 <label>
Use positive flow accumulation even for likely underestimates
 </label>
<description>
See manual for a detailed description of flow accumulation output
 </description>
</flag>
<flag name="overwrite">
 <description>
</description>
 </flag>
<flag name="verbose">
<description>
 Verbose module output
</description>
</flag>
 <flag name="quiet">
<description>
Quiet module output
 </description>
</flag>
</task>
On Mon, Nov 14, 2011 at 7:02 PM, Sandip Maity <sandip.stesalit at gmail.com>wrote:
> Dear frnd,
> I want
> 1> to keep input option on required screen.
> 2> to keep only minimum size of exterior basis of input option.
> 3> to keep first and third parameter of output option.
> All are in first screen( with required screen) .
> please suggest me.
> thanks and regards.
> Sandip.
> On Mon, Nov 14, 2011 at 5:30 PM, Mohammed Rashad <
> mohammedrashadkm at gmail.com> wrote:
>> what are changes you are planing. pleasse be more secific
>> and dont be shy to ask on grass-dev
>> On Mon, Nov 14, 2011 at 5:27 PM, Sandip Maity <sandip.stesalit at gmail.com>wrote:
>>> Dear frnd
>>> I am planning to change in GUI  for watershed basin analysis.
>>> Actually the GUI asking to many datas. I want to fixed the parameter to
>>> make easy to handle.
>>> please help me.
>>> thanking for your suggetion and waiting for more suggetion.
>>> sandip
>>> On Mon, Nov 14, 2011 at 4:36 PM, Mohammed Rashad <
>>>> move to grass-dev ML.
>>>> gui is not very active now a days. and be specific when asking questions
>>>> r.watershed is the module you are looking for...
>>>> folder is raster/r.watershed . Its not gui in python its C code you
>>>> need to familiar with and in my opinion should swich to UNIX-like PC for
>>>> these work and its my own opnion.
>>>> please dont start operating system wars!!!
>>>> gui is gnerated from an xml format .Each grass module have
>>>> interface-description and based on that gui parsers will generate the form
>>>> structure. What changes are you planning to make.?
>>>>   On Fri, Nov 11, 2011 at 5:06 PM, Sandip Maity <
>>>> sandip.stesalit at gmail.com> wrote:
>>>>>   Dear sir,
>>>>> I want to modify the existing code of watershed analysis.
>>>>> Please tell me in which file or folder i should go for changing the
>>>>> code?
>>>>> I have to change some or modify the form structure.
>>>>> Please help me.
>>>>> regards.
>>>>> Sandip.
>>>>> _______________________________________________
>>>>> grass-gui mailing list
>>>>> grass-gui at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-gui
>>>> Regards,
>>>>    Mohammed Rashad K M
>>>>    M.S. (By Research) student
>>>>    Lab for Spatial Informatics
>>>>    Department of CSE
>>>>    International Institute of Information Technology
>>>>    Hyderabad, India
>> Regards,
>>    Mohammed Rashad K M
>>    Department of CSE
>>    Hyderabad, India
Regards,
   Mohammed Rashad K M
   Department of CSE
   Hyderabad, India
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111114/282ab240/attachment-0001.html
