[GRASS-dev] How can I cange or modify the GUI for watershed analysis?
Sandip Maity sandip.stesalit at gmail.com
Tue Nov 15 07:36:07 EST 2011
Dear Soren,
I have used grass64 -text to run
"r.watershed --wps-process-description > r_watershed_process.xml"
and
"r.watershed --interface-description > gui.xml"
GUI.XML is created but it is the size of zero byte.
please help.
Sandip
2011/11/15 Sören Gebbert <soerengebbert at googlemail.com>
> 2011/11/15 Sandip Maity <sandip.stesalit at gmail.com>:
> > Dear Martin,
> > I am using WXPYTHON.
> > So, where I can use this comand "r.watershed--interface-description"
> > Please help me.
> Open a GRASS shell and type:
> To create a XML file, type:
> Don't forget the space between r.watershed and --interface-description.
> In case you want a WPS XML process description to use with PyXB type:
> Soeren
> > sandip
> > On Tue, Nov 15, 2011 at 4:26 PM, Martin Landa <landa.martin at gmail.com>
> >> > Dear frnd,
> >> > I am not getting "-interface-description".
> >> > Please suggest me how can i get gui.xml?
> >> ML
> >> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20111115/dbba82fd/attachment.html
