[GRASS-dev] Preparing GRASS GIS 6.4.2RC2
Helena Mitasova hmitaso at ncsu.edu
Tue Nov 15 15:33:53 EST 2011
Markus,
please hold on a few hours so that I can double check here with students
who were testing the RC1. So far everything was running smoothly but I
would like to check.
The only thing that caused a problem was the legend (see below) but I
did not have time
to try it myself and put it into bug tracker if it indeed is a problem.
I will try later today, (there are just too many things going on),
thanks,
Helena
When I tried to set the legend properties for the global radiation at
the summer solstice (Figure 9 Global
Radiation at Summer Solstice), I received an error. This error
occurred in GRASS 6.4.1 and 6.4.2. The
result was a legend that showed all values the same color. Setting the
legend properties in the Winter
Solstice map did not result in an error.  The error trace from the
command window is pasted below. This
requires further investigation.
 Error in Legend Traceback (most recent call last):
  File "C:\Program Files (x86)\GRASS
6.4.SVN\etc\wxpython\gui_modules\menuform.py", line 622, in
OnOK
cmd = self.OnApply(event)
6.4.SVN\etc\wxpython\gui_modules\menuform.py", line 637, in
OnApply
self)
  File "c:/osgeo4w/usr/src/grass64_release/dist.i686‐pc‐
mingw32/etc/wxpython/gui_modules/gdialogs.py", line 569, in
GetOptData
  File "c:\OSGeo4W\apps\Python25\lib\site‐packages\wx‐2.8
‐msw‐unicode\wx\_core.py", line 14526, in __getattr__
wx._core
PyDeadObjectError
The C++ part of the DecorationDialog object has been
deleted, attribute access no longer allowed.
On Tue, Nov 15, 2011 at 2:55 PM, Markus Neteler <neteler at osgeo.org> wrote:
> hi,
> since there are no more blocker bugs
> http://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&group=type&order=priority&priority=blocker&priority=critical&milestone=6.4.2&milestone=6.4.1&milestone=6.4.0
> it is time to get out RC2 now. I discussed with MartinL and MarkusM (both
> here in the office) so nothing came to mind why not to get RC2 out.
> More in a short while
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Helena Mitasova
Associate Professor
Department of Marine, Earth and Atmospheric Sciences
North Carolina State University
1125 Jordan Hall
NCSU Box 8208
Raleigh, NC 27695-8208
http://skagit.meas.ncsu.edu/~helena/
email: hmitaso at ncsu.edu
ph: 919-513-1327 (no voicemail)
fax 919 515-7802
