[GRASS-dev] Vect_*_fatal_error()
Thu Nov 17 10:44:54 EST 2011
Martin Landa wrote:
> > I know that this solution doesn't follow the idea of calling modules
> > (and not using library directly), but now it seems to be much easier
> > to do this change than rewrite parts of wxGUI which uses ctypes.
> I am afraid that rewriting such wxGUI components with the number of
> active developers (GRASS or better to wxGUI only) it's quite
> unrealistic task.
Leaving things as it is and hoping that the reliability issues "go
away" is even more unrealistic. At least a re-write will eventually
result in a solution.
> Moreover it would go against the integration
> efforts. It would basically mean to separate eg. vector digitizer to
> the standalone application similarly how worked old-fashioned
> `v.digit` module. It means to make step(s) back (in my POV) and to
> split the whole wxGUI to more standalone applications.
The alternative is something which cannot help but be unreliable.
