[GRASS-dev] r.reclass only for int maps
Mon Oct 10 04:18:45 EDT 2011
Michael Barton wrote:
> I originally raised this question with regard to discrete values maps
> whose values are floating point numbers, not maps in which floating
> point numbers represent a continuous field (e.g., as in an elevation
> map).
> An example might be a soil map with a limited number of discrete values
> for K-factor.
> Whether integers or floating point numbers are used, r.reclass only
> makes sense in the context of a map with a small number of discrete
> values. In that case questions about approximations do not really apply.
> It should just be a simple 1 to 1 mapping like we have for integers.
> Are the limitations you mention a function of the data type itself or
> more about what the cell values represent?
They're mostly an issue of the nature of the cell values themselves.
Realistically, a look-up table requires that the values are integers,
and cover a relatively small range.
The actual code (from lib/raster/get_row.c) which performs the reclass
does:
    struct fileinfo *fcb = &R__.fileinfo[fd];
    CELL *c = cell;
    CELL *reclass_table = fcb->reclass.table;
    CELL min = fcb->reclass.min;
    CELL max = fcb->reclass.max;
    int i;
    for (i = 0; i < R__.rd_window.cols; i++) {
	c[i] = reclass_table[c[i] - min];
IOW, the number of entries in the reclass table is (max-min+1), i.e.
it contains entries covering the range of values, including any gaps.
So if you have an integer map consisting of two values, 1000000000 and
2000000000, then the look-up table needs 1000000001 entries.
Floating-point values can't be used as array indices directly, and
converting them to integers for use as array indices would require a
scale factor chosen such that distinct floating-point values map to
distinct integers. Given that a set of floating point values can
include both very small values and very large values, it wouldn't be
hard to come up with data which required an infeasibly large look-up
table.
For "category" data such as:
> for K-factor.
the ideal solution would be to allow reclassing an integer map *to* a
floating-point map (i.e. the look-up table could contain float/double
values). The underlying map would contain integer category numbers,
while a reclassed version would contain the corresponding
floating-point "factor" values.
Some modules support this by allowing category labels to be parsed as
floating-point values (e.g. r.mapcalc's '@' modifier, r.statistics' -c
flag, etc). But allowing reclassing to floating-point would work for
all modules.
Extending the reclass feature to support "on-the-fly r.recode"
functionality would be a much bigger issue.
