[GRASS-dev] r.pack failing on reclassed maps
Hamish hamish_b at yahoo.com
Thu Oct 13 09:51:27 EDT 2011
Glynn wrote:
> In any case, there doesn't appear to be a
> supported programmatic method for determining
> that a map is a reclass.
at the filesystem level, checking the first line of
cellhd/$map_name gives you the info.
Hamish
