[GRASS-dev] Re: [GRASS GIS] #1463: Legend, Zoom to map, Map analysis and Map query does not work in Python wxgui using command line d.mon + d.rast
GRASS GIS trac at osgeo.org
Sat Oct 15 12:14:36 EDT 2011
 Reporter:  huhabla      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  d.mon        |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by martinl):
 Replying to [comment:1 huhabla]:
 > Is it possible to create an "invisible" dummy LayerTree, filled with
 information about the map to be drawn from command line? So that the
 depending functionality in mapdisplay.py works?
 I think that it's better to fix `mapdisp.py` in the sense to avoid using
 LayerTree when starting wx display using `d.mon`. It seems to me that a
 dummy Layer Tree is not necessary, or better to say it would be anything
 usable.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1463#comment:2>
