[GRASS-dev] [GRASS GIS] #1471: Interactive geometry selection and export tool for wxgui
GRASS GIS trac at osgeo.org
Sun Oct 16 14:49:05 EDT 2011
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 Currently there is no easy way how to select single or multiple vector
 objects in the map display for later usage or export.
 Vector selection tool should provide following functionality:
  * ability to select vector feature type for selection (important for area
 vs centroid/boundary)
  * ability to get geometry ID list as a result
  * ability to get CAT list as a result
  * ability to save result as a new GRASS vector data map
  * ability to visually identify list item on the screen
  * ability to remove items from list
Ticket URL: <http://trac.osgeo.org/grass/ticket/1471>
