[GRASS-dev] Re: [GRASS GIS] #1478: Too many files in destination directory v.out.ogr, write fails
GRASS GIS trac at osgeo.org
Fri Oct 21 12:40:45 EDT 2011
 Reporter:  MarjanM444             |       Owner:  grass-dev@…
     Type:  defect                 |      Status:  new
 Priority:  normal                 |   Milestone:
Component:  Vector                 |     Version:  6.4.1
 Keywords:  Export, vector, write  |    Platform:  All
      Cpu:  x86-64                 |
Comment(by glynn):
 Replying to [ticket:1478 MarjanM444]:
 > If there are more than 1024(350?) files in destination directory, the
 write is not successfull. THis was proven to be problem on Linux as MS
 Windows platform. The problem is present for long time, please either
 document the behaviour or present a workaround.
 v.out.ogr just passes the dsn= argument to OGR_Dr_CreateDataSource(). If
 there's a problem, it's in OGR itself, so I can only suggest reporting
 this to the GDAL/OGR maintainers.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1478#comment:3>
