[GRASS-dev] [GRASS GIS] #1435: Quotes are stripped from command display
GRASS GIS trac at osgeo.org
Sun Sep 4 22:59:44 EDT 2011
 Reporter:  arencambre  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:
Component:  wxGUI       |     Version:  unspecified
 Keywords:              |    Platform:  MSWindows 7
      Cpu:  x86-64      |
 In GRASS GIS Layer Manager's '''Command Console''', if I type a command
 with quotes, such as '''v.in.ogr -o dsn="...DSN goes here..." ...''', the
 quotes are stripped from the display when the command is repeated back at
 me in the output window after I press enter.
 This is significant because the positioning of quotes makes a huge
 difference in how commands are interpreted.
 This is in version 6.4.1 (not available in the dropdown).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1435>
