[GRASS-dev] [GRASS GIS] #1438: g.remove cannot remove vector map
trac at osgeo.org
Sun Sep 4 23:09:48 EDT 2011
Reporter: arencambre | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: unspecified
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
I have a vector map named '''pointdata'''. I can confirm this because if I
run '''v.in.ogr''' against a PostGIS database with '''output''' set to
'''pointdata''', the command's output is:
'''ERROR: Vector map <pointdata> already exists'''
Yet when I run '''g.remove pointdata''', I get:
'''Removing raster <pointdata>
Raster map <pointdata> not found
<pointdata> nothing removed'''
But then you may say, "Hey, moron, that's a vector layer! Use the right
command." OK, I ran '''g.remove vect=pointdata''' and I get:
'''Removing vector <pointdata>
DBMI-DBF driver error:
Unable to open database <cat C:\Users\Aren Cambre\Desktop\DEEM
documents\GRASS\DallasCountyCrashes\Crases2\dbf\> by driver <dbf>
Unable open database <cat C:\Users\Aren Cambre\Desktop\DEEM
Unable to find table <crash> linked to vector map <pointdata>
couldn't be removed
I've attached a copy of the mapset in concern.
This is for GRASS GIS 6.4.1 (that option not available in the
'''Version''' dropdown).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1438>
