[GRASS-dev] GRASS 7 scripts overhaul
Hamish hamish_b at yahoo.com
Mon Sep 5 04:31:41 EDT 2011
Hamish wrote:
> the point of storing the history is so that you can see the
> non-obvious conditions which led to the map as it now exists, so
> you can understand + recreate it. In that sense storing
> i.landsat.rgb's info in the history is justified. (& basically
> the entire point of having a history..)
specifically, for recording the state of the strength= and -p flag.
Unlike r.colors, it is not possible, even with a trained eye and
direct inspection of the colr/ file, to determine the input command
which created the present output.
Hamish
