[GRASS-dev] Re: [GRASS GIS] #1444: g.parser does not filter for duplicate output map statements
GRASS GIS trac at osgeo.org
Wed Sep 7 02:54:40 EDT 2011
 Reporter:  neteler  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  minor    |   Milestone:  6.4.2
Component:  LibGIS   |     Version:  6.4.1
 Keywords:  parser   |    Platform:  All
      Cpu:  All      |
Changes (by hamish):
  * keywords:  => parser
Comment:
 It would seem that by design (at least in 6.5) if you use a command line
 parameter more than once the parser concatenates them together with ',' as
 the f.sep.:
 r.series in=roads in=fields out=both method=count
 r.info -h both
    r.series input="roads,fields" output="both" method="count"
 if the particular option does not allow multiple="YES", you get an error.
 perhaps a way to handle this is for the parser to be more upfront about
 scanning for illegal map names &/or if multiple=NO?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1444#comment:2>
