[GRASS-dev] Location EPSG code storage
Markus Neteler
neteler at osgeo.org
Thu Sep 8 17:02:53 EDT 2011
On Tue, Aug 30, 2011 at 8:04 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello all,
> as EPSG codes have become de-facto standard way of identifying various
> SRS'es in various services and other places, we need a way how to sore
> locations EPSG code, if it's known. Currently when creating a new
> location by EPSG code, this information gets lost. There is no easy
> way how to determine current location EPSG code required to connect
> any OGC WxS service. Comparing proj parameters from epsg file is not
> failproof.
I would like to see the EPSG code additionally stored.
> Options:
> a) add a new key-value pair to PROJ_INFO
> + all information is stored in single place
> + projection information reading/writing code is already inplace
> - it needs to be changed to deal with a new key-value pair
> - breaks backwards compatibility
For sure it breaks it? I didn't look at the routines.
> - EPSG code might not be known for most of (existing) locations
> b) create a new file (epsg) in PERMANENT
> + doesn't affect current projection information management
> - information lives separate from rest of projection information
> - requires new functions to read/write this info
> I would like to hear other developer opinion before any changes to
> core parts are implemented.
If it breaks backwards compatibility, then only b) seems to be a
solution.
Markus
