[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows
fails with "Unable to delete vector map"
trac at osgeo.org
Fri Sep 9 06:11:05 EDT 2011
#1158: Removing vector map in Windows fails with "Unable to delete vector map"
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: Vector | Version: 6.4.0
Keywords: wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by lutra):
> Selecting multiple vectors (in the QGIS/GRASS mapset browser) and
removing them (with the remove button) leads to corruption of the vectors,
the mapset become unusable and it is needed to delete manually the vector
folders/files (not before closing QGIS).
after all it seems if that no one of the selected vectors is being
rendered in the QGIS canvas, then is possible to remove them without any
issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:50>
