[GRASS-dev] Re: [GRASS GIS] #1441: Hard Copy Map Utility (wxPython wrapper for ps.map) text overlay is broken
GRASS GIS trac at osgeo.org
Fri Sep 9 07:41:00 EDT 2011
 Reporter:  cmbarton                       |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  6.4.2
Component:  wxGUI                          |     Version:  svn-trunk
 Keywords:  hard copy map utility, ps.map  |    Platform:  Unspecified
      Cpu:  Unspecified                    |
Comment(by annakrat):
 Replying to [comment:11 cmbarton]:
 > The way I've got it set up now is that it will try to use typefaces with
 names Times, Helvetica, or Courier, depending on which one of these ps.map
 fonts is picked. If it can't find one, it will revert to the "default"
 font family for the system. This can be fine tuned.
 Thanks for the patch, I changed a little (r48220) the makePSFont method,
 it was not working for me.
 Anna
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:13>
