[GRASS-dev] Re: [GRASS GIS] #1441: Hard Copy Map Utility (wxPython wrapper for ps.map) text overlay is broken
GRASS GIS trac at osgeo.org
Fri Sep 9 19:05:50 EDT 2011
 Reporter:  cmbarton                       |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  6.4.2
Component:  wxGUI                          |     Version:  svn-trunk
 Keywords:  hard copy map utility, ps.map  |    Platform:  Unspecified
      Cpu:  Unspecified                    |
Comment(by cmbarton):
 I just committed the fixes I've been working on the past several days, but
 also incorporated all your changes prior to committing.
 r48226
 This seems to fix all prior problems except for a very weird one that I
 hope you have some insight into. For map info, the background and border
 shows up fine if the map info text is positioned in the top half of a
 page. If it is positioned in the bottom half of the page, the text
 displays fine, but the background and border disappear. Even odder, this
 behavior does NOT happen with the text objects.
 If this tests out for other systems, maybe it can be backported, though
 the map info behavior is still not quite right.
 Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:20>
