[GRASS-dev] Re: [GRASS GIS] #1441: Hard Copy Map Utility (wxPython wrapper for ps.map) text overlay is broken
GRASS GIS trac at osgeo.org
Fri Sep 9 21:34:05 EDT 2011
 Reporter:  cmbarton                       |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  6.4.2
Component:  wxGUI                          |     Version:  svn-trunk
 Keywords:  hard copy map utility, ps.map  |    Platform:  Unspecified
      Cpu:  Unspecified                    |
Comment(by hamish):
 Replying to [comment:20 cmbarton]:
 > This seems to fix all prior problems except for a very weird one that
 > I hope you have some insight into. For map info, the background and
 > border shows up fine if the map info text is positioned in the top
 > half of a page. If it is positioned in the bottom half of the page,
 > the text displays fine, but the background and border disappear.
 > Even odder, this behavior does NOT happen with the text objects.
 that's a known problem, see #192 comment 5.
  https://trac.osgeo.org/grass/ticket/192#comment:5
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1441#comment:21>
