[GRASS-dev] [GRASS GIS] #1447: wxGUI wingrass scripts need
	whitespace in path
    trac at osgeo.org
    Sat Sep 10 12:15:18 EDT 2011
#1447: wxGUI wingrass scripts need whitespace in path
 Reporter:  mmetz   |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  normal  |   Milestone:  6.4.2
Component:  wxGUI   |     Version:  svn-releasebranch64
 Keywords:          |    Platform:  MSWindows XP
      Cpu:  All     |
 In wingrass wxGUI, whenever a file path is entered as input for a script,
 the script will fail if the path does '''not''' contain whitespace and
 succeeds only if the path does contain whitespace.
 Example:
 # define options in wxGUI:
 v.in.geonames input=D:\GRASS_test_data\IT\IT.txt out=italy_geonames
 # output
 ERROR: File 'D:GRASS_test_dataITIT.txt' not found
 # that works in wxGUI:
 v.in.geonames input=D:\GRASS test data\IT\IT.txt out=italy_geonames
 Interestingly, both commands
 v.in.geonames input="D:\GRASS test data\IT\IT.txt" out=italy_geonames
 work from the command line.
 Also interestingly, this affects only scripts, not C modules, e.g.
 v.in.ogr always works whereas e.g. v.in.geonames fails from wxGUI if the
 command line does not contain at least one whitespace in the absolute
 path.
 g.parser receives from the wxGUI
 and
 D:\\GRASS test data\\IT\\IT.txt
 Within the wxGUI, as far as I was able to trace the strings, they were
 D:\\GRASS_test_data\\IT\\IT.txt
 and
 that is, ok.
 At some stage, the backslashes "\" are removed if no whitespace is in the
 string and correctly converted to "\\" if a whitespace is in the string. I
 was not able to find this stage in wxGUI and lib/python. I guess this is
 one tiny single line of python code messing up the string. Any
 suggestions?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1447>
