[GRASS-dev] GRASS 7 scripts overhaul
Mon Sep 12 14:24:14 EDT 2011
Markus Neteler wrote:
> > Try r48225.
> Now a different one:
> line 267, in main
>     y, z = yz.split(' ')
> ValueError: too many values to unpack
I've improved m.proj as much as I can.
The main problem is that, when cs2cs is run with the -E flag, it
appears to copy the input semi-verbatim, meaning that the output
format varies according to the input format. This makes it impossible
to reliably parse the output from cs2cs.
