[GRASS-dev] [GRASS GIS] #1448: run model menu item does not seem to work
GRASS GIS trac at osgeo.org
Tue Sep 13 16:01:12 EDT 2011
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.2
Component:  Default      |     Version:  svn-trunk
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 I made and saved a model using the graphical modeler. The model works
 fine. I can load the saved model into the graphical modeler and it works
 fine.
 If I select "run model" from the file menu and select this saved model,
 nothing happens. No error and nothing produced.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1448>
