[GRASS-dev] v.bd.addtable
Martin Landa landa.martin at gmail.com
Thu Sep 15 16:19:30 EDT 2011
2011/9/15 Roger Bivand <Roger.Bivand at nhh.no>:
> #% type: integer
> is missing in the 6.4 release branch for the interface description of layer
fixed in r48304.
> in v.db.addtable around line 36. It is in trunk, and in 6.4.1 released.
> Without it, the type is inferred to be string.
Note that in GRASS7 layer is a string. It supports layer names (not
only layer numbers) and OGR layer names when accessing external data
directly using OGR [1].
Martin
[1] http://grass.osgeo.org/wiki/Working_with_external_data_in_GRASS_7#Direct_access_to_external_data
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
