[GRASS-dev] Re: [GRASS GIS] #1450: grass 6.4.svn nightly build fails on startup
GRASS GIS trac at osgeo.org
Fri Sep 16 18:45:04 EDT 2011
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  6.4.2
Component:  wxGUI     |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32    |
Comment(by hellik):
 Replying to [comment:3 hellik]:
 > Replying to [ticket:1450 hamish]:
 > > Hi,
 > > I just downloaded the latest nightly 6.4svn build r48286
 > > the without msys icon doesn't launch grass, the with-msys gives this
 error in the terminal after you chose your mapset and click [continue] ..
 > tested with WinGRASS-6.4.SVN-r48305-1-Setup.exe on a german
 WinVista32-box
 > I can't reproduce this error.
 > starting wingrass with/without msys are starting normally here.
 and also tested here with WinGRASS-6.4.SVN-r48286-1-Setup.exe, but I'm
 even not able to reproduce the error here on my german winvista32-box.
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1450#comment:4>
