[GRASS-dev] Re: [GRASS GIS] #730: sqlite: troubles with datetime columns: unable to parse decltype: datetime
GRASS GIS trac at osgeo.org
Mon Sep 19 04:16:03 EDT 2011
 Reporter:  neteler   |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.0
Component:  Database  |     Version:  6.4.0 RCs
 Keywords:            |    Platform:  All
      Cpu:  All       |
Comment(by mmetz):
 Replying to [ticket:730 neteler]:
 > There are some troubles with datetime columns in SQLite:
 [snip]
 > Not sure what to do: map to which DB_SQL_TYPE_xxx?
 The SQLite documentation says that datetime is of the format "YYYY-MM-DD
 HH:MM:SS". According to lib/db/dbmi_base/datetime.c, DB_SQL_TYPE_TIMESTAMP
 seems to be an exact match. Try trunk r48359.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/730#comment:1>
