[GRASS-dev] Re: [GRASS GIS] #757: WinGRASS: GUI window from cmd line
GRASS GIS trac at osgeo.org
Tue Sep 20 05:15:07 EDT 2011
  Reporter:  silviap       |       Owner:  grass-dev@…
      Type:  task          |      Status:  closed
  Priority:  trivial       |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:  wontfix       |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Changes (by hamish):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Glynn wrote:
 > When you run the command without arguments, the GUI
 > interface is only generated if stdin is a terminal,
 > according to isatty().
 > On Windows, isatty() only recognises the standard
 > Windows Command Prompt as a terminal. The MSys
 > terminal (rxvt) isn't considered a terminal by isatty()
 > You can still force a GUI using the --ui switch.
 the problem is well understood; I just tested and the --ui work-around
 still works; closing the ticket with the nearest reason to "cantfix".
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:12>
