[GRASS-dev] Re: [GRASS GIS] #1198: Error while parsing file paths in WiNGRASS with Python Script
GRASS GIS trac at osgeo.org
Tue Sep 20 05:26:32 EDT 2011
 Reporter:  luislisboa1975  |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  6.4.1
Component:  wxGUI           |     Version:  svn-releasebranch64
 Keywords:  wingrass        |    Platform:  MSWindows XP
      Cpu:  Unspecified     |
Comment(by hamish):
 is this from within a specific grass module, from the wxGUI command entry
 box, or from a self-written script?
 the `\` is used to quote the character which follows it verbatim.
 so `C:\Program Files\GRASS\scripts` reduces to `C:Program
 FilesGRASSscripts`.
 one solution as pointed out is to use `/` instead. Another way is to use
 two of them, so that the second one gets quoted verbatim: `\\`.
 ISTR that some OS-specific magic was added to the wxGUI command parser,
 but I suspect the solution to this will ultimately be education:
 gratuitous tooltips and inset Caution-boxes in the wxGUI help pages.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1198#comment:2>
