[GRASS-dev] Re: [GRASS GIS] #1220: Error when creating vector(areas) from raster
GRASS GIS trac at osgeo.org
Tue Sep 20 05:38:24 EDT 2011
  Reporter:  toyzerocha1980  |       Owner:  grass-dev@…
      Type:  defect          |      Status:  closed
  Priority:  major           |   Milestone:  6.4.1
 Component:  Vector          |     Version:
Resolution:  wontfix         |    Keywords:  wingrass, memory, r.to.vect
  Platform:  MSWindows XP    |         Cpu:  x86-32
Changes (by hamish):
  * keywords:  wingrass => wingrass, memory, r.to.vect
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 closing the ticket as "wontfix" (aka can't fix), if you want to work with
 huge datasets the solutions seem to be installing more RAM and/or a more
 capable 64bit OS.
 building topology in GRASS 6.4 is going to get memory hungry and with
 32bit WinXP there's a hard RAM limit that we can't do much about.
 you can try to use the `r.to.vect -b` flag to skip building topology, but
 that's mostly useful for point data, not areas.
 you can also try running the module on a smaller raster region, then
 `v.patch` the results back together and dissolve out any seam boundary
 lines.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1220#comment:8>
