[GRASS-dev] Re: [GRASS GIS] #957: v.voronoi has extra lines in output
GRASS GIS trac at osgeo.org
Tue Sep 20 05:59:05 EDT 2011
 Reporter:  helena  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  6.4.2
Component:  Vector  |     Version:  svn-develbranch6
 Keywords:          |    Platform:  All
      Cpu:  All     |
Comment(by hamish):
 Replying to [comment:9 mmetz]:
 > the extents are stored with insufficient precision in WIND:
 > region north: 306221.83019368
 > vector north: 306221.830193683563
 I would suggest that since this is in the 5 nanometer range, and WIND is
 seemingly stored to `%.14g` (or does that happen when reading the vector's
 &window?), that we verify that `printf(%.15g)` is used when writing the
 WIND file and then if needed use GRASS_EPSILON to test.
 I would suggest ignoring such corner cases in the code, keep using fast >=
 tests, and recommend in the docs that `g.region vect=` should be used with
 the `-a and res=` options in most cases.
 I'm not sure where the %.14g is coming from, as lib/gis/wind_format.c
 writes using %.15g.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/957#comment:11>
