[GRASS-dev] Re: [GRASS GIS] #1450: grass 6.4.svn nightly build fails on startup
GRASS GIS trac at osgeo.org
Tue Sep 20 08:43:09 EDT 2011
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  6.4.2
Component:  wxGUI     |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32    |
Comment(by hamish):
 installing msvcr71.dll didn't help. I didn't try msvcp71.dll as well,
 although a colleague using Windows7 needed both those (in that case it
 asked for them by name).
 In order to fix the `WindowsError: [Error 14001] This application has
 failed to start` error I was getting on a fresh Windows XP machine I
 needed to install the Microsoft .NET Frameworks 3.1 followed by 3.5.
  http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=25
  http://www.microsoft.com/download/en/details.aspx?id=21
 perhaps the .NET Frameworks version 4 download helps too, but does not
 require the earlier versions to be installed first? (not tested)
 suggested solution is to add some text to the wingrass README.html
 troubleshooting section.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1450#comment:7>
