[GRASS-dev] Re: [GRASS GIS] #1448: run model menu item does not seem to work
GRASS GIS trac at osgeo.org
Tue Sep 20 13:58:13 EDT 2011
  Reporter:  cmbarton     |       Owner:  martinl
      Type:  defect       |      Status:  closed
  Priority:  critical     |   Milestone:  6.4.2
 Component:  wxGUI        |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  modeler
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by cmbarton):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Tested and it seems to work fine. I ran into an error initially that I
 traced to the fact that the output argument for r.blend has changed in
 GRASS 7 from "output" to "output_prefix" . A more accurate name for the
 argument but it breaks backward compatibility (permitted across version
 changes of course).
 Thanks again for making this very nice tool for GRASS. I've already been
 recommending it as a way to get started writing Python scripts. I'll go
 ahead and close this.
 BTW, how does the variables section work for the modeler?
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1448#comment:10>
