[GRASS-dev] Re: [GRASS-SVN] r48376 - in grass/trunk: lib/python lib/temporal temporal temporal/t.create temporal/t.time.abs temporal/t.time.rel
Tue Sep 20 23:29:45 EDT 2011
Martin Landa wrote:
> btw, the messages should be marked for translation. Also string
> substitutions is preferable, it's better for translators. In this case
> core.error(_("Unable to remove space time dataset register table ") + self.get_stds_register())
Use:
core.error(_("Unable to remove space time dataset register table %s") % self.get_stds_register())
Using substitution allows the position of the subject/object to be
changed if that's appropriate for a particular language. Appending
means that it has to come at the end, which can sometimes require
contrived and/or grammatically incorrect translations.
If a string contains more than one substitution, it's better to use
the dictionary form, to allow the order to be changed. Unlike C's
printf(), Python doesn't support the "%1$s" notation.
