[GRASS-dev] Re: [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken (was: wingrass wx location wizard doesn't ask for datum transform options)
GRASS GIS trac at osgeo.org
Tue Sep 20 23:51:35 EDT 2011
 Reporter:  hamish                         |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  critical                       |   Milestone:  6.4.2
Component:  Projections/Datums             |     Version:  svn-releasebranch64
 Keywords:  wingrass, location wizard, wx  |    Platform:  MSWindows XP
      Cpu:  x86-32                         |
Comment(by hamish):
 * It seems that upstream epsg file is broken. (!)
 on Wingrass 6.4svn nightly build:
 in the projection wizard, proj=ll datum=nad27 does give the datum
 transform table menu
 in the projection wizard, proj=ll datum=nad83 does '''not''' give the
 datum transfotm menu.
 for one NAD83 datum found in the epsg file:
 g.proj epsg=4152 datumtransform=-1
 gives this error:
 WARNING: Datum <NAD83_High_Accuracy_Regional_Network> not recognised by
         GRASS and no parameters found
 however another datum=nad83 (epsg:4269) does show table.
 at this point I went poking around and noticed that the $PROJ_LIB/epsg
 file on wingrass is '''missing''' a lot of datum= and instead had expanded
 +towgs84= terms. If datum= had remained you might be able to work around
 it, but that has not been preserved.
 locally I have proj 4.7.0 installed: epsg file is ok.
 wingrass ships proj 4.7.1: epsg file includes lots of +towgs84 terms that
 are not part of the formal epsg definition! they've just been irreversibly
 expanded on a random assumption.
 crap.
 fwiw proj 4.7.1 has not been formally released AFAIK (so why the @#$!!
 heck is osgeo4w shipping it??)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1452#comment:3>
