[GRASS-dev] Re: [GRASS GIS] #1101: WinGrass7 + scripts are not found in the command line
GRASS GIS trac at osgeo.org
Tue Sep 20 23:55:13 EDT 2011
 Reporter:  hellik             |       Owner:  grass-dev@…
     Type:  defect             |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  Packaging          |     Version:  svn-trunk
 Keywords:  wingrass, scripts  |    Platform:  MSWindows Vista
      Cpu:  Unspecified        |
Comment(by glynn):
 Replying to [comment:10 hellik]:
 > any hints to look why there seems to be tried invoking shell scripts
 instead of the pythonized scripts in grass70svn?
 1. Does %PATH% contain the "scripts" directory?
 2. Does PATHEXT include ".PY"?
 !#2 isn't required for bash, which will recognise the "#!/usr/bin/env
 python" lines provided that there's a Python interpreter in $PATH (which
 shouldn't be the case, but probably is with the OSGeo4W setup). But
 cmd.exe (and Python itself) will use the file associations for the .PY
 extension (which Python will set up if it's installed correctly).
 BTW, I believe that the "sh.exe" is because you're typing the commands
 into the shell, not because something is trying to execute the command as
 a shell script.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1101#comment:11>
