[GRASS-dev] Re: [GRASS GIS] #1453: ps.map: various enhancements
GRASS GIS trac at osgeo.org
Thu Sep 22 05:27:33 EDT 2011
 Reporter:  mmetz        |       Owner:  hamish
     Type:  enhancement  |      Status:  assigned
 Priority:  normal       |   Milestone:  7.0.0
Component:  Ps.map       |     Version:  svn-trunk
 Keywords:               |    Platform:  All
      Cpu:  All          |
Comment(by mmetz):
 Replying to [comment:1 hamish]:
 > re. comments in the script, fyi they are already allowed but the # must
 be the first char of the line IIRC (less than ideal). your patch as given
 for # as first non-whitespace char of the line requires a space after it
 to work? that is less than ideal too.
 No following whitespace required. If the first non-whitespace and non-tab
 character is #, the line is skipped. Whatever comes after # is ignored.
 > note I've been meaning to do a bit of a rewrite of the vector legend
 stuff. I prefer the rectangles (esp. when mixed with lines and points in
 the legend) but am happy to make the shape adjustable somehow. Jorge has
 some ideas worth looking at as well.
 The shape is a matter of taste I guess.
 > vpoints should be under the grid lines, but points (ie annotations)
 should be above.
 That is what the patch does (it's about vpoints, not points).
 > if present in the instruction, the "masked y|n" control can help control
 the order
 > things get rendered in.
 The "masked" control is recognized for vpoints, now exactly the same like
 for vector lines and areas.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1453#comment:3>
