[GRASS-dev] Re: [GRASS GIS] #1447: wxGUI wingrass scripts need whitespace in path
GRASS GIS trac at osgeo.org
Thu Sep 22 05:39:06 EDT 2011
 Reporter:  mmetz             |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  major             |   Milestone:  6.4.2
Component:  wxGUI             |     Version:  svn-releasebranch64
 Keywords:  wingrass, spaces  |    Platform:  MSWindows XP
      Cpu:  All               |
Comment(by mmetz):
 Replying to [comment:3 benducke]:
 > What I find strange is that I see the same behavior on Windows with
 MSYS' sh.exe, without the wxGUI. I am running GRASS shell scripts through
 the SEXTANTE/GRASS interface of gvSIG. What this interface does is set up
 the GRASS env variables, create a GRASS mapset, then import the data and
 call sh.exe to parse the script. The GRASS I use is CLI only and the
 system does not even have Python installed. Thus my initial guess that the
 problem goes deeper than wxGUI.
 Hmm, with wingrass CLI it always works for me, as long as file paths are
 quoted if they contain spaces. Quoting is not necessary for file paths
 without whitespace.
 In wxGUI, the command plus args disappears in a Python Queue, up to there
 it seems ok.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1447#comment:5>
