[GRASS-dev] Re: [GRASS GIS] #1447: wxGUI wingrass scripts need whitespace in path
GRASS GIS trac at osgeo.org
Sat Sep 24 11:04:22 EDT 2011
 Reporter:  mmetz             |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  major             |   Milestone:  6.4.2
Component:  wxGUI             |     Version:  svn-releasebranch64
 Keywords:  wingrass, spaces  |    Platform:  MSWindows XP
      Cpu:  All               |
Comment(by glynn):
 Replying to [comment:11 mmetz]:
 > > subprocess.Popen() has to convert the argument list to a command
 string according to the rules by which MSVCRT parses the command string
 into arguments, so that the program's main() ends up seeing the correct
 argv[]. One of those rules is that strings containing whitespace must be
 quoted.
 > That's all fine for programs that have a main(), but shell scripts don't
 have main().
 sh.exe does, and it uses argv[i] as the basis for the $<i>. It may perform
 conversions (e.g. filename translation) on the individual arguments, but
 it doesn't merge argv[] back into a string then parse it back into
 individual arguments. However, with "-c", it will end up parsing the
 resulting string into a command and arguments.
 > I think that is the reason why the current implementation works for real
 programs but not for scripts. MSVCRT rules do not (need to) cater for
 strings passed to cmd.exe, then to %GRASS_SH%.
 cmd.exe has the same argument parsing rules as MSVCRT. Once an argument
 list has been converted to a string, prepending "cmd.exe /c " to the
 beginning of the string is supposed to be a no-op, except that the
 "program" is no longer restricted to binary executables.
 > AFAICT, a file path without whitespaces is passed ok to the Windows
 shell (cmd.exe), but then further passed to %GRASS_SH%, yet another shell,
 and there the (by now unprotected) backslashes get lost if not quoted
 properly.
 Aha. The problem is with scripts/windows_launch.bat:
 @"%GRASS_SH%" -c '"%GISBASE%/scripts/SCRIPT_NAME" %*'
 It should be:
 @"%GRASS_SH%" "%GISBASE%/scripts/SCRIPT_NAME" %*
 The former approach can't be made to work. There is no practical way to
 write a batch file which will reliably turn a program and a list of
 arguments into a Bourne-shell command which will execute that program with
 those arguments. Any attempt will work for simple cases but fail for
 arguments which contain shell metacharacters (space, backslash, quote,
 etc). cmd.exe's string handling is too primitive to do it right.
 The latter approach simply runs the shell with the argument list which was
 passed to the script, but with the path to the script "pushed" onto the
 front (i.e. the original arguments are shifted along one place). This is
 exactly how Unix handles a shebang. If this doesn't work, it's because of
 "workarounds" elsewhere which try to compensate for this.
 > The strings indicating file paths do have escaping under Windows within
 the wxGUI, but it's \ that is escaped to \\, looks fine to me.
 Are you sure that it isn't Python doing this? Just to be sure, can you add
 e.g.:
 f = open('debug.txt', 'w')
 f.write(repr((args, kwargs)))
 f.close()
 immediately before the subprocess.Popen.__init__ call?
 If those doubled backslashes are actually in the strings, that's a bug
 which needs to be fixed. subprocess.Popen() does the required quoting, and
 it gets it right. Note that backslashes will be doubled by repr(); if
 there are quad backslashes, that means they've really been doubled.
 > These strings are converted somewhere inside subprocess.Popen to protect
 whitespaces, but not to protect backslashes (escapes).
 The only conversion which subprocess.Popen() performs is to convert the
 argument list to a string according to the MSVCRT/cmd.exe rules. If you
 write a C program which just prints out main()'s argv[], it will show the
 exact argument list which was passed to subprocess.Popen().
 > I'm pretty sure that this is the problem for scripts
 I'm pretty sure that the core problem is with windows_launch.bat, as
 described above. There may well be other bugs which were introduced to
 attempt to "cancel out" the  bug in windows_launch.bat.
 > The fix causes subprocess.Popen to protect everything because the
 program and its args are passed as one single string which means that
 protection of single arguments, e.g. input="D:\Grass_test_data\IT\It.txt"
 must be done manually.
 This is an attempt (probably not the first) to "cancel out" the actual
 bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1447#comment:12>
