[GRASS-dev] Re: [GRASS GIS] #1447: wxGUI wingrass scripts need whitespace in path
GRASS GIS trac at osgeo.org
Sat Sep 24 15:58:45 EDT 2011
 Reporter:  mmetz             |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  major             |   Milestone:  6.4.2
Component:  wxGUI             |     Version:  svn-releasebranch64
 Keywords:  wingrass, spaces  |    Platform:  MSWindows XP
      Cpu:  All               |
Comment(by glynn):
 Replying to [comment:13 mmetz]:
 > The result has double, not quad backslashes, i.e. seems to be ok:
 ((['v.in.geonames', 'input=D:\\GRASS_test_data\\IT\\IT.txt
 out=italy_geonames', 'output=IT'])), {'shell': True, 'stdin': -1,
 'stderr': -1, 'stdout': -1}]
 That looks fine.
 > > I'm pretty sure that the core problem is with windows_launch.bat, as
 described above.
 > You're right, thanks a lot for your help! I have committed the change to
 windows_launch.bat in 6.4 and 6.5, r48448 and r48449, respectively.
 One minor caveat: v.krige will need to create its own batch file on
 Windows, as it's a Python script, not a shell script.
 "sh -c 'prog arg arg'" will run arbitrary commands: executables, shell
 built-ins, shell scripts, or other scripts (for which it will use the
 shebang). The cost is that the argument to -c will be parsed, so it must
 be properly constructed (i.e. quoted) according to bash syntax. "sh prog
 arg arg" will only run shell scripts, but will pass the arguments
 verbatim, without having to worry about parsing.
 As it's a "mixed mode" script (GUI or non-GUI, depending upon whether
 there are any arguments), we can't rely upon the .py extension; it needs
 to be run via GRASS_PYTHON, e.g.:
 @"%GRASS_PYTHON%" "%GISBASE%\scripts\v.krige.py" %*
 (This means that v.krige is broken for a different reason in 7.0; it needs
 to be split into separate Python and Python+wxPython scripts, as is done
 for wxpyimgview).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1447#comment:14>
