[GRASS-dev] Re: [GRASS GIS] #1454: v.outlier manual page does not refer that the vector needs to be a 3D one
GRASS GIS trac at osgeo.org
Tue Sep 27 05:03:47 EDT 2011
  Reporter:  lutra        |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  6.4.2
 Component:  Docs         |     Version:  6.4.1
Resolution:  fixed        |    Keywords:  v.outlier
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by neteler):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:5 hamish]:
 > Replying to [comment:3 martinl]:
 > > So `v.outlier` should complain if input is 2D vector data, right?
 > yes,
 > Vect_is_3d() seems to be the test to use..
 You mean the test which *is* used:
    /* Input vector must be 3D */
     if (!Vect_is_3d(&In))
         G_fatal_error(_("Input vector map <%s> is not 3D!"),
 in_opt->answer);
 Manual fixed, closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1454#comment:6>
