[GRASS-dev] wxGUI: column name selector?
Markus Metz markus.metz.giswork at googlemail.com
Wed Sep 28 02:42:16 EDT 2011
On Tue, Sep 27, 2011 at 11:26 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2011/9/27 Markus Neteler <neteler at osgeo.org>:
>> while d.vect is able to provide in the wxGUI the list of available
>> columns other modules are yet unable (v.db.univar, v.*).
> it should work for almost all vector modules (please report modules,
> where it doesn't work).
> There is a bug in v.db.univar - option <table> wrongly defines
> gisprompt for vector. Fixed in r48508.
> BTW, I would expect from this module options like `map` and `layer`,
> not `table`, `driver` and `database`. Modules `v.db.` should come with
> `map` option, or I am wrong?
I agree. v.db.univar should have options 'map' and 'layer', not
'table', 'driver', and 'database'. Otherwise it would need to be
called db.univar, not v.db.univar.
Markus M
