[GRASS-dev] wxGUI: column name selector?
Markus Metz markus.metz.giswork at googlemail.com
Wed Sep 28 06:45:21 EDT 2011
On Wed, Sep 28, 2011 at 11:13 AM, Martin Landa <landa.martin at gmail.com> wrote:
> 2011/9/28 Hamish <hamish_b at yahoo.com>:
>> Markus Metz wrote:
>>> I agree. v.db.univar should have options 'map' and 'layer', not
>>> 'table', 'driver', and 'database'. Otherwise it would need to be
>>> called db.univar, not v.db.univar.
>> since there is already a v.univar module like that, renaming to db.univar
>> seems like the path to take.
> seems to be. Martin
+1, makes sense to me
I was considering if the interface should be changed, but db.univar
with table, driver, database options is more versatile than a
v.db.univar with map, layer options would be.
Markus M
