[GRASS-dev] Re: [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
GRASS GIS trac at osgeo.org
Wed Sep 28 07:47:50 EDT 2011
 Reporter:  hamish                   |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  critical                 |   Milestone:  6.4.2
Component:  Projections/Datums       |     Version:  svn-releasebranch64
 Keywords:  location wizard, g.proj  |    Platform:  All
      Cpu:  All                      |
Comment(by hamish):
 Replying to [comment:6 hamish]:
 > wingrass 6.5svn r48515 nightly build on XP w/MSys:
 > #spearfish
 > g.region -d
 > g.region -n
 > WARNING: pj_transform() failed: failed to load datum shift file
 > ERROR: Error in pj_do_proj (projection of input coordinate pair)
 > `g.region -l` gives the same error.
 this bug is likely to be wingrass related though. (perhaps libproj +
 spaces in pathname problem?) if so it could go into a new ticket.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1452#comment:9>
