[GRASS-dev] GRASS 6.4.2RC1 planning
Wed Sep 28 14:54:57 EDT 2011
Hamish wrote:
> one that failed was d.barb, it failed looking for -lfreetype, although
> libfreetype6.so.* is found in /usr/lib.
That won't help; it would have to be using -lfreetype6 rather than
-lfreetype.
> but not the static lib which
> ships with the libfreetype6-dev package. After install the freetype -dev
> package it built ok. d.barb only uses R_text(), not freetype directly, so
> I'm not sure if that's to be expected or not.
Has FreeType been updated since the base GRASS package was built?
I don't see anything about d.barb which looks different to any other
d.* module.
