[GRASS-dev] Re: [GRASS GIS] #1420: wxGUI: modeller
GRASS GIS trac at osgeo.org
Wed Sep 28 18:10:23 EDT 2011
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.2
Component:  wxGUI        |     Version:  svn-releasebranch64
 Keywords:  addons       |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by hamish):
 Replying to [comment:2 martinl]:
 > In r48545 the addons modules are at least scanned.
 do not scan $GRASS_ADDON_PATH/bin/ and $GRASS_ADDON_PATH/scripts/. rather
 just scan $GRASS_ADDON_PATH. executables are (ie should be) symlinked back
 into there if they happened to be installed to ./bin/ or ./scripts/. (I
 see no reason why with a little more work bin/ and scripts/ couldn't be
 skipped entirely, and save the trouble of the symlinking)
 the $GRASS_ADDON_PATH variable is meant to be part of the $PATH variable,
 it is not meant to be --prefix= or $ADDON_BASE. (see also William's
 approach using $GRASS_ADDON_ETC found in lib/gis/find_etc.c and documented
 in macosx/Readme.rtf)
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1420#comment:3>
