[GRASS-dev] GRASS7: makefile issue with -j4
Martin Landa landa.martin at gmail.com
Thu Sep 29 16:37:35 EDT 2011
2011/9/29 Markus Neteler <neteler at osgeo.org>:
> when compiling G7 after make distclean, always
> Errors in:
> /home/neteler/grass70/gui/wxpython/docs
> when using make -jX. A second run solves it.
> Trivial, but it would be nice to see that fixed. My Makefile foo
> is not sufficient for this.
the exact error on my machine
make[6]: Entering directory `/usr/local/src/grass_trunk/gui/wxpython/docs'
/usr/bin/install -c  -m 644 wxGUI_GCP_Manager.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_GCP_Manager.jpg
/usr/bin/install -c  -m 644 wxGUI_layer_manager.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_layer_manager.jpg
/usr/bin/install -c  -m 644 wxGUI_map_display.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_map_display.jpg
/usr/bin/install -c  -m 644 wxGUI_nviz_toolbar.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_toolbar.jpg
/usr/bin/install -c  -m 644 wxGUI_nviz_tools_light.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_light.jpg
/usr/bin/install -c  -m 644 wxGUI_nviz_tools_surface.jpg
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_surface.jpg
/usr/bin/install: /usr/bin/install: cannot create regular file
`/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_surface.jpg'cannot
create
: File exists: File exists
make[6]: *** [/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI_nviz_tools_surface.jpg]
Error 1
make[6]: Leaving directory `/usr/local/src/grass_trunk/gui/wxpython/docs'
Error 1
make[5]: *** [/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI.Attribute_Table_Manager.html]
Error 2
make[5]: *** Waiting for unfinished jobs....
make[5]: *** [/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI.GCP_Manager.html]
Error 2
make[5]: *** [/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/docs/html/wxGUI.Modeler.html]
Error 2
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
