[GRASS-dev] Re: [GRASS GIS] #1464: Bug on v.buffer
GRASS GIS trac at osgeo.org
Mon Apr 30 14:16:50 EDT 2012
 Reporter:  leonidas  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Vector    |     Version:  svn-trunk
 Keywords:  v.buffer  |    Platform:  All
      Cpu:  All       |
Changes (by mmetz):
  * platform:  Linux => All
  * cpu:  x86-32 => All
  * milestone:  6.4.2 => 7.0.0
Comment:
 Fixed in trunk in r51580, as long as GRASS is compiled with GEOS. Neither
 one of the two GRASS-internal buffering methods is working correctly.
 Moreover, the GEOS method is the only one allowing for internal buffers
 with negative distances. Should we disable v.buffer if GEOS is not
 available (rather have no result than a wrong result)?
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1464#comment:4>
