[GRASS-dev] [GRASS-SVN] r52607 - grass/trunk/raster/r.lake
Sat Aug 11 11:08:36 PDT 2012
Markus Neteler wrote:
> then it should be changes in *all* GRASS.
No, it shouldn't be changed at all.
This change cannot be made in the case where the format string has
parameters, so there's no reason to change it for the parameter-less
case.
Please revert.
