[GRASS-dev] [GRASS GIS] #1651: Map display Query Vector tool fails
GRASS GIS trac at osgeo.org
Tue Aug 21 03:01:09 PDT 2012
 Reporter:  vincent        |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:  6.4.3
Component:  wxGUI          |     Version:  svn-releasebranch64
 Keywords:  query, vector  |    Platform:  Linux
      Cpu:  Unspecified    |
Changes (by neteler):
  * keywords:  queryvector => query, vector
Comment:
 I have made a test with the NC data:
 g.region rast=elev_lid792_1m -p
 r.contour elev_lid792_1m out=contours step=2.5
 v.univar contours type=line col=level
 Then loading the map into the display, right-mouse to define
 Properties -> Selection -> WHERE -> level % 100 = 0
 It no longer crashes but generates a DBMI/DBF error since "%" is
 not supported. That looks correct. For SQLite and PostgreSQL it
 should work.
 Can you please retry with a current 6.4.svn version?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1651#comment:1>
