[GRASS-dev] [GRASS GIS] #1817: Map Swipe
GRASS GIS trac at osgeo.org
Sun Dec 2 05:22:37 PST 2012
#1817: Map Swipe
 Reporter:  hellik  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  normal  |   Milestone:  7.0.0
Component:  wxGUI   |     Version:  svn-trunk
 Keywords:          |    Platform:  MSWindows 7
      Cpu:  x86-64  |
 choosing the bottom/right raster, press ok, then following error comes up:
   File "C:\OSGeo4W\apps\Python27\lib\site-packages\wx-2.8
 -msw-unicode\wx\_core.py", line 14669, in <lambda>
 lambda event: event.callable(*event.args, **event.kw) )
   File "C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\gui\wxpython
 \mapswipe\frame.py", line 103, in CallAfterInit
 self.OnSelectRasters(event = None)
 \mapswipe\frame.py", line 303, in OnSelectRasters
 res1 = self.SetFirstRaster(name = maps[0])
 \mapswipe\frame.py", line 324, in SetFirstRaster
 self.OnZoomToMap(event = None)
 \mapswipe\frame.py", line 287, in OnZoomToMap
 self.GetFirstWindow().ZoomToMap(layers =
 self.Map.GetListOfLayers())
 \mapswipe\mapwindow.py", line 103, in ZoomToMap
 super(SwipeBufferedWindow, self).ZoomToMap(layers,
 ignoreNulls, render)
 \mapdisp\mapwindow.py", line 1583, in ZoomToMap
 layers = self.tree.GetSelectedLayer(multi = True,
 checkedOnly = False)
 AttributeError
 'NoneType' object has no attribute 'GetSelectedLayer'
 System Info
 GRASS version: 7.0.svn
 GRASS SVN Revision: 54132
 GIS Library Revision: 52468 (2012-07-27)
 GDAL/OGR: 1.9.2
 PROJ.4: 4.8.0
 GEOS: 3.3.5
 SQLite: 3.7.10
 Python: 2.7.2
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1817>
