[GRASS-dev] [GRASS GIS] #1813: RST lib quad_divide_data calls exit with 0
GRASS GIS trac at osgeo.org
Tue Dec 4 04:53:58 PST 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Raster       |     Version:  svn-trunk
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by marisn):
 Attached file contains a 3D shapefile with data stripe and hole in the
 middle. The goal is to interpolate data from surrounding points to fill
 the hole.
 Unzip file, create a new location based on provided file. Remove imported
 vector file and import it again this time with -z option (see bug #1822).
 Set region and run interpolation:
 g.region -a res=20
 v.surf.rst -z input=interpolate_this layer=1 elev=filled_hole
Ticket URL: <http://trac.osgeo.org/grass/ticket/1813#comment:1>
