[GRASS-dev] [GRASS GIS] #1821: r.water.outlet: accept vector points map instead of plain coordinates for outlet
GRASS GIS trac at osgeo.org
Mon Dec 3 21:19:20 PST 2012
outlet
 Reporter:  dericke      |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Raster       |     Version:  unspecified
 Keywords:  watershed    |    Platform:  Unspecified
      Cpu:  Unspecified  |
 Similar to r.walk, r.water.outlet should accept either an easting and
 northing (as it currently does), or a points map (with optional SQL query)
 to define the outlet point(s).
 The cat field of the points file could be optionally used as the raster
 value for each basin created.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1821>
